Topic: Duel soundcard? - Hardware? - Broadcasting?
DJ HainHome userMember since 2005
Hi all!
Right here is my dilema, I have totally got sucked in DJ-ing why I never did this sooner i will never know, what I need to do, is basically I have a one sound card set up no additional hardware, what I am basically looking to achieve if possible, is to be able to plug my headphones in and hear the next track as well as pumping the tunes out as normal, also is there anything (cheap pref) hardware wise i can add to Virtual DJ to make it more realistic as there is only so much I can do at once with a mouse pointer! :o)
Also does anyone use the broadcase function if so any details would help!
Thank you all so much
DJ Hain
geposted Mon 28 Nov 05 @ 4:31 pm
Well first of all what you are looking to do is definatelly possible.
1st a VDJ licence is needed as the function is disabled in the demo.
2nd as far as controller you can buy the Hercules DJ Console or DAC 2 or DAC 3 controller which will look better then just a mouse.
If you really want to spend some cash you can always buy a dual CD player or 2 single cd decks or turntables and a mixer and use TCCD/TCVs.
Best Regards
DJ White Devil
geposted Mon 28 Nov 05 @ 6:21 pm
Thank you v much DJ White Devil! I appreciate the help, best get saving! lol
DJ Hain :o)
geposted Wed 30 Nov 05 @ 5:39 pm
hehe no worries buddy I know all about that ;)
geposted Wed 30 Nov 05 @ 7:16 pm
