Hello:
I have installed Ice Cast on my dedicated server and have configured the latest VDJ to broadcast over Icecast but I CANNOT get it to connect. I have the correct URL to the server, the correct port defined the correct username and password.
Is there something else I need BETWEEN VDJ and The Icecast Option on VDJ or can anyone give me any tips. Am I missing something?
Have tested icecast on the server with another program it IS working. Any suggestions would be greatly appreciated!
Thanks in advance.
Theresa
Thanks in advance.
Theresa
geposted Wed 30 Nov 05 @ 1:22 pm
just a thought..... tell me if im way off !!! config setup, general tab, multi user on, and security off ??? perhaps? i know i know but i wanna try help its the least i can do !!
geposted Wed 30 Nov 05 @ 1:31 pm
Thanks for the try but NO that did not work. Is the icecast option all inclusive in the latest VDJ or is there something else I need to do to actually get it to broadcast to an icecast server?
geposted Wed 30 Nov 05 @ 3:02 pm
you have the acsess look for a plug in on VDJ something like C:Program FilesWinampPluginsdsp_ic.dll ?? try that also is your firewall up or down???? might not be alowing VDJ to pass through??
geposted Wed 30 Nov 05 @ 4:00 pm
