Anyone with numeric usb numpad ? Try something for me.
Well i bought one to setup some shortcuts but it react different than the numkeys in a normal 105 keyboard.
I want to see if this is the standard for keypads or it is only mine.
Connect the numpad and open config->add add shortcut in virtualdj and try some keys.
The sent key message should be in the shortcuts page.
2 main differences, numlock and enter keys:
1. The numlock key does not send the standard numlock command.
For this i have to press and hold the key for a few seconds.
Single press does nothing but change the "internal" mode of the keypad
between standard numkeys 1-9 and arrows,home,end,page up/down etc
2. Enter key send standard "Enter" command instead of "Num Enter"
geposted Wed 30 Nov 05 @ 4:51 pm
same thing with me apopsis (Addison SKP-19)
Num Lock does not give a keycode at all even if i press it for years. Enter gives a normal enter not a numeric.
geposted Thu 01 Dec 05 @ 12:55 am
That's bad, i needed these keys..
thanks.
thanks.
geposted Thu 01 Dec 05 @ 3:52 am
TENKSE
geposted Thu 01 Dec 05 @ 3:55 am
YUO HEPPY..
geposted Thu 01 Dec 05 @ 3:56 am
