After setting karaoke output to second monitor, the screen is blank unless a song is playing and displaying the lyrics. Can you change it so that windows background or specified bitmap/jpg shows while no song is playing? I have my DJ logo as windows background and would like it to display between karaoke songs.
Thanks,
Troy
aka DJ Hot Sauce
Thanks,
Troy
aka DJ Hot Sauce
geposted Sun 25 Dec 05 @ 5:05 pm
In 3.0-3.2 go into options, choose video option. Check show bitmap image. Click the box next to it. Point to the folder where the image or images are. If you want a slideshow to occur click the slideshow. Make sure you also have a folder with the image in it so you can point vdj to look at the file or in that folder and have a merry christmas.
geposted Sun 25 Dec 05 @ 5:16 pm
