I am having some problems with my Virtual DJ trial because it doesnt even let me start using it because it is looking for an update and this is the 3rd time that I tried to load it. This is the message I get when i try to load the program "Virtual DJ will now try to connect to the internet and check if a new version is available. You can disable this action in the config menu at any time". Then it tells me to press OK and when I do it doesn't even load the program.
geposted Mon 02 Jan 06 @ 10:00 pm
Hi there,
That sounds like the typical behaviour of a cracked version (not saying you intended to use an illegal version).
Uninstall the currently installed version and install the Latest Trial version from this website:
http://www.download.com/Virtual-DJ/3000-2170-10212112.html?part=dl-VirtualDJ&subj=dl&tag=button
geposted Mon 02 Jan 06 @ 10:40 pm
thanks for the help imma try and find out if it bothers me
geposted Tue 03 Jan 06 @ 12:05 am
