Can anyone tell me everything I need to use the timecoded vinyl with my DJ Console MK2? The set up I have now is the Virtual DJ software that came along with the DJ Console MK2, a direct drive turntable (haven't purchased the vinyl yet) and my computer. What else do I need? Do I have to purchase the upgraded software in addition to everything else I've purchased? And if so, what is the advantage pricewise with this solution opposed to just purchashing Rane Serato?
geposted Tue 03 Jan 06 @ 8:04 pm
@ blackice Welcome to the community ! Check here for discounts to getting your sticky paws on the full pro version.
http://www.virtualdj.com/purchase/discount.html
Unfortunately the software that comes boxed with consoles are the home edition versions thus limiting VDJ's full potential,
On the price/competitor, comparison side of things here is the best link for that http://www.virtualdj.com/products/comparison.html
Other than that your will just need the vinyl's (look pocket wise at buying 4 vinyl's ! ) although they do last the saving you via shipping if u were to buy another 2 later would have paid for them itself .
and er.....correct me if I'm wrong you would also need a decient asio sound card.
Hope that gets u started ?
Oh and http://www.virtualdj.com/products/hardware.html If you want to read up a bit more on the TCV.
Hope that helps
Spin spin
Hope that helps
Spin spin
geposted Wed 04 Jan 06 @ 12:38 am
As far as I know, the Hercules won't allow inputs and ASIO the way that VDJ needs for doing TCV. I think you'll need to do like I do with my xp10s, which is not use the built in soundcard and instead use an external soundcard that has enough inputs and outputs to do TCV and ASIO also.
geposted Wed 04 Jan 06 @ 1:02 am
@Anewsome, woohoo I was correct when I said all you will need is a decient asio sound card and you good to go !
I'm learning, I'm learning!
ha ha
ha ha
geposted Wed 04 Jan 06 @ 1:14 am
So i'm guessing that my plan to buy some TTs and use the HDJC2 as the mixer and the input soundcard would fail then? :'o( I'm guessing it's back to the original plan of betting a maya44/delta44 and some tts and a mixer then?
Happy new year (I know it's late but it's my first post of the year)
Nebula
Nebula
geposted Wed 04 Jan 06 @ 3:53 pm
