Whats the "booth" connection on a mixer?
I never use it...
I never use it...
geposted Tue 03 Jan 06 @ 10:21 pm
its a separate controllable line output of a mixer and it is used to be connected to a separate amplifier (no eq's, no compressors etc) and at last, to connect the speakers of your booth only! in order for the dj to hear final output unfiltered (no delays etc)hope that helped
geposted Tue 03 Jan 06 @ 11:02 pm
You typically need a booth output on the mixer for a booth speaker, or monitor as we call it. When you are DJing at the club, the main speakers on the dancefloor are useless for mixing since the delay is too much to compensate for at most clubs, unless you're right on top of the dance floor. It's also nice to be able to turn your personal booth volume up or down without affecting the mains. It's almost guaranteed that you will need a mixer with a seperate booth and main (at least), for most clubs.
geposted Tue 03 Jan 06 @ 11:18 pm
Thanks, I know exactly what it is now :)
geposted Wed 04 Jan 06 @ 4:11 am
my booth and floor are my bedroom, lol
-gauge
"i'm patiently waiting for a plane to fly home..."
-gauge
geposted Wed 04 Jan 06 @ 11:30 am
You can also use the booth line out to record mixes if you're using an external mixer. The booth out goes back into the soundcard to record.
geposted Wed 04 Jan 06 @ 4:43 pm
The usefullness of the booth out for recording depends on the mixer. Some booth outputs dont route the microphone audio to the booth, which is nice because if I am recording my mix, I don't want my crowd hyping drops to ruin my mixtape,.. but then again I guess sometimes you would.
geposted Wed 04 Jan 06 @ 8:52 pm
