First I would like to say that i think its not cool that i should have to pay another hundred dollers for just to be able to download the ID3 Tag parser My question is if i pay for this upgrade and want to use timecoded vinyl will i need an interface like finalscratch or can i run it direcly trhough the MK2 Console ?? and if so can i eliminate the Console with a Numark or other USB mixer ?? thanks again in advance
geposted Fri 06 Jan 06 @ 9:52 pm
you'll need 2 turntables of course and you can connect them to the MK2 console since it has a built in ASIO soundcard.
The console comes with an adapted trial version of the full pro version.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Fri 06 Jan 06 @ 10:02 pm
where can you look at the download of the id3 tag parser?
geposted Thu 09 Feb 06 @ 4:33 pm
All right guys,i know that is a pain in the ass but,you can have a id3 tags for free,i have over 30.000 songs and i had that same problem.now i'm free....
go to www.magnusbrading.com/mp3ts/
DVJ Bruno.
geposted Thu 09 Feb 06 @ 9:50 pm
what ID3 parser? i dont think VDJ uses ID3 info appart from artist and songtitle.
geposted Fri 10 Feb 06 @ 12:32 am
I've come across so many id3 tag editors and that is by far the best one I've used. Thanks Bruno!
geposted Fri 10 Feb 06 @ 12:39 am
