Is it possible to prelisten when you have 1 sound card, and 1 usb headset?
geposted Sun 08 Jan 06 @ 7:35 pm
Hello Vanbriel,
You can use a USB headset to pre-listen (or to cue the next song) ONLY when you have purchased Virtual DJ. Basically, the various sound card options unlock once you enter a valid software key. I personally use a PlayStation 2 Logitech USB Headset, which came with a game, and it works a treat!!
Hope this helps,
Cheers,
Richard
Hope this helps,
Cheers,
Richard
geposted Sun 08 Jan 06 @ 10:26 pm
Thanx a lot
geposted Mon 09 Jan 06 @ 12:41 am
Although for proffesional DJ use I would advise against USB headphones personally, they will do the job but regular DJ headphones way exceed them IMO.
geposted Mon 09 Jan 06 @ 12:48 am
