Hey i've got a quick question. When I was testing out the trial version of Virtual DJ, one of the buttons had like a stutter on it that I loved using and I'm having trouble figureing out which option that is in the FX section of the program. If anyone knows what i'm talking about cna you help me either figure out which FX this is called or where to download it on here?
Thanks so much gang!!
Cheers,
DJ White Raven
Cheers,
DJ White Raven
geposted Tue 10 Jan 06 @ 4:14 am
beat grid :) Its only available for full users, sorry
geposted Tue 10 Jan 06 @ 10:15 am
i'm not sure i understand what you mean by full users. i own a copy of the program and use it at home does this not constitute being a "Full User"?
Regards,
Kim
Regards,
Kim
geposted Tue 10 Jan 06 @ 12:29 pm
There are several versions of our program.
What I meant was pro user. You are a full user for sure ;)
But the level for download is different, some are available for all users, some for Home Edition users, and some for Pro edition users...
Actually, you plugin might be available for you. If it was not installed with your version, download the pro demo, and you should have the Beat Grid plugin also
Hope that helps :)
Hope that helps :)
geposted Tue 10 Jan 06 @ 12:39 pm
