Topic: Play from CUE with DAC-3
Hello all, How do you start a song from a cue point in the other player with the DAC-3 ?
geposted Wed 18 Jan 06 @ 9:28 pm
Do you mean go to (And play) from a cue point other than number 1?
I'm not sure with the native DAC-3 support (Don't use it), but with my custom DAC-3 mapper, you can jump directly to cues 1-4 with the 1-4 buttons and set them with CP+1-4 (5-10 do loops - If you want direct access to cues 5-10, you can change the button assignments with user parameters.)
You can also select the current cue point (1-12) with CP + left/right buttons - Play and cue will then work with that cue point. The large digits show the current cue point.
geposted Wed 18 Jan 06 @ 11:32 pm
