Topic: what do i need to use virtual dj using decks
hi i dont own a copy yet,
but i would like to know if i get the software does it come with a box so i can connect my 1210 decks to the programme and use the time vinyl? like vinyl scratch
cheers
geposted Fri 20 Jan 06 @ 5:47 pm
No, it does not come with an interface box like Final Scratch, because in Virtual DJ, you do not need one. You can use your 1210's, or a cd player, as VDJ utilizes Timecoded vinyl and Timecoded cd's.
geposted Fri 20 Jan 06 @ 8:16 pm
You'll probably want to get a sound card with enough inputs and outputs too. The Maya 44 USB seems to be a popular choice, although it is not regarded as a high quality card. I have two of them and they work pretty well with VDJ and timecode.
You'll also need to buy the timecoded vinyl from this site.
geposted Fri 20 Jan 06 @ 8:47 pm
how do i then connect my laptop to the decks/mixer and sync it up?
geposted Sat 21 Jan 06 @ 8:11 pm
