how do i connect my laptop to the decks/mixer and sync it up with the time code cd?
geposted Sat 21 Jan 06 @ 8:16 pm
The Demo version is restricted to only 1 deck and not in ASIO mode so you will get a brief view of how it works. Of course the full version and a good ASIO sound card will make it work much better.
-First connect your CD deck to your soundcard's line in
-connect your line out to your mixer's line in (deck A)
-open VDJ and go into the soundcard options tab
-find and select the one with 2 turntables and a mixer
-click ok and test it out.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Sat 21 Jan 06 @ 11:43 pm
