Hi,
I used VDJ attached to an external mixer a few weeks ago. What I thought was somewhat odd, was the fact, that VDJs internal "mixtable" was not disabled. For example the crossfader on my dj console could accidentally fade in/out music.
Maybe some people make some use of this fact, but I´d rather would like to have the possiblity to switch it off.
So not much - just make it possible to disable the mixer controls.
Thanks.
Thanks.
geposted Thu 06 May 04 @ 9:52 am
Use a "pro" skin, that is made just 4 that reason. No fader/levels/eq.
geposted Thu 06 May 04 @ 12:52 pm
this is true with the pro skins however if you use automix and it pulls the cross fader either to the left or the right you cannot recenter it because it is nolonger on the skin. just because the feature is not on the skin doesn't disable it. you could create a shortcut to recenter the main crossfader however you will still not visually be able to see the position of it.
i have thought of a feature such as this for quite a while now just never bothered for some reason to post it
this would be quite a easy function to add however give the user the option to enable or disable it.
perhaps create a list of functions within vdj and have a tick box on / off for all the main functions
geposted Thu 06 May 04 @ 4:06 pm
A shortcut to automatically center the crossfader would be a good idea
I use an external mixer (Rane MP2) and use the ext_mixer.zip skin
geposted Fri 07 May 04 @ 1:01 am
In the next version of the Pioneer CDJ-700S, you'll find a button 'reset crossfader' in the 'pro' pannel.
geposted Fri 07 May 04 @ 9:17 am
