Forum: Old versions
Topic: DJConsole Virtually Rocks Australia
ewazHome userMember since 2004
The first time I dreamed of a console like the abovementioned to be before me like a golden portal to unexplored realms of digital-jock mixing. I believe the trial version of Atomix MP3, which was without all the fancy features it has been embedded with over the last few years, was my V-DIGI-J application of choice. I had so much stuff backed up on CD's in MP3 format... a good 20 discs jammed full at least... Man it was a course mastering the skill of being able to successfully use the mouse to produce some good mixes! But now, at long last, Australia is graced with the operative method of control.
Smooth Interactive - Shop [HI-TECH A/V] - Product ViewSearch for same Brand or Category. Product Code: DJCONSOLE. Short Description:
Tactile DJ USB control unit for mixing/scratching. ... Enquire about the DJCONSOLE.
www.smoothinteractive.com/store/ productview.php?code=DJCONSOLE
geposted Fri 07 May 04 @ 1:52 am
