Topic: Trial version
StyxWGHome userMember since 2006
It wont work, every time i try to go on it, it comes up and says there is an error and i have to send an error report, so i re-download and it still doesnt work... anyone know why this is happening?
geposted Wed 01 Feb 06 @ 3:17 am
Hi,
First uninstall all VirtualDJ you have.
Also you have to delete virtualDJ directory
c:\\program files\\VirtualDJ
and also delete the registry entries thru regedit look for VirtualDJ or VDJ
then reboot and reinstall the demo.
If this does not help, contact http://www.virtualdj.com/contact/
Probably you were using VDJ demo previously, or some "bad versions"
geposted Wed 01 Feb 06 @ 10:05 am
I did what you told me and it still doesnt work, i dont see how i could get a "Bad Version" i downloaded it right from this website, idk i wanted to try it out before i spend 150 bucks but i guess im not gonna be able to try it out ;(
geposted Wed 01 Feb 06 @ 7:10 pm
Like Lopez said:
Please send a message with the error message. You should fill the following form
The VDJ team will try to help you.
Ewout
geposted Wed 01 Feb 06 @ 8:37 pm
