can someone tell me if these are the same thing that vdj is selling if so why vdj so high can you tell me are these the same as Dj console mk2 which ones is better thanks for the help
http://www.djdeals.com/herculesDJCONTROL.htm
http://www.jr.com/JRProductPage.process?Product=4057318
geposted Fri 03 Feb 06 @ 5:19 am
There is no entry for headphone on the front side ?! ôO
geposted Fri 03 Feb 06 @ 5:24 am
This is what I understand. The model you are looking at is the DJ Console MP3. It does not have a soundcard in it. You will need a mixer for headphone cueing. Then there is The MK1, which has a dual soundcard, and you are able to cue with a headphone. The new MK2 has some some added features, that I know nothing about. From what I understand, it is built better. The buttons and switches are suppose to be stronger, and to last longer. As you can see, I do not have all the answers, but hope I helped a little bit.
geposted Fri 03 Feb 06 @ 8:18 am
Hercules DJ console
-it was first with internal 6 channel soundcard and one microphone and line input.
-it has some problems with sometimes ignoring pushing the buttons sound was quite good
- has virtual dj 1.09 bundled with it
Hercules DJ control MP3
- it is exactly the same as Hercules DJ console but without soundcard, just the wheels and buttons
-has Virtual DJ 3.2 bundled
- the price is about the half of DJconsole
Hercules DJ console MKII
- it has newer buttons and jogwheels, little more functions (regarding prelistening)
- it has soundcard with 2 inputs and 2 outputs so you can use Timecoded vinyl and connect two turntables to hercules
- price is almost the same as the Djconsole
geposted Fri 03 Feb 06 @ 9:36 am
