hello:)
I'm Martin from Poland:), and a newbe at this forum and with VirtualDJ(v3.3)
can you help me please? i have 2 turntables, mixer, Maya 44usb, 2 Timecode Vinyls(FS) and a problem....
at my soundcard ->4 inputs works correct, but a final mixed sounds comes up from only 2 outputs....and 2 are not works at all....i check allready all posibilities with program and i see at Time-Coded Vinyl Configuation -> OUTPUT looks: [Chan:1&2 Master] and i can't change it ! could someone tell me why?is that a problem with ASIO drivers?
geposted Fri 17 Feb 06 @ 1:39 am
Hi
Well, first I'm sorry to tell you that FS TimeCoded vinyls don't work with VirtualDJ, you need VirtualDJ TimeCoded Vinyls.
Second, maybe the problem you have with the configuration is because the demo doesn't allow sound card configuration, that can only be done in the full version. And in the demo as far as I know you can only test one TCV.
geposted Fri 17 Feb 06 @ 2:37 am
What Alberto said is true in the trial version you can only use one tcv and the soundcard is not configurable.
Nikki
Nikki
geposted Fri 17 Feb 06 @ 9:33 am
thank you:)
you've right.only one TCV with demo versoion...but i don't agree with you Alberto, FS vinyls works with VDJ.but don't figured out why the music plays a little bit faster than it should be, but when i buy full version that problem might be solved via full options at configuration.
geposted Fri 17 Feb 06 @ 10:51 am
soot,
VDJ will only work properly with VDJ and D-Vinyl Timecode vinyls.
Ewout
Ewout
geposted Sat 18 Feb 06 @ 5:09 pm
and with d vinyl only with the d vinyl interface
geposted Sun 19 Feb 06 @ 3:10 am
thanks for the addition Xeo, I forgot to mention that you need the d-vinyl controller indeed to get it working.
Ewout
Ewout
geposted Sun 19 Feb 06 @ 2:53 pm
