What are the settings for using TCCD? Do u use the setting that says TCV?
geposted Sat 25 Feb 06 @ 11:20 pm
I was curious about that so I looked at it like 5 mins ago. Go here: http://www.virtualdj.com/products/timecode/ and scroll down.
geposted Sat 25 Feb 06 @ 11:26 pm
Thank you sooooooo much!
geposted Sat 25 Feb 06 @ 11:31 pm
OK, I have done this and have muted out the in on the monitors and I still have a problem when using the tccd. Can anyone help? My problem is that it locks up when using the TCCD's, has this happen before?
geposted Sat 29 Apr 06 @ 10:21 pm
what setup are you using ? Try lower the volume into the pc from the decks. They play too loud
geposted Sun 30 Apr 06 @ 2:40 pm
Open the Config Timecode menu. Then open up the advanced menu. Try to get the signal at 100%. Like dj-in-norway already said is that you probably have to lower the input volume on your sound card (By clicking on Asio configon the Timecode setup screen).
Ewout
Ewout
geposted Sun 30 Apr 06 @ 4:30 pm
Thanks guys and yes, it was a volume issue that was the problem. I had to mute out from the control panel/sound device the line-in and pow, it worked out fine!
geposted Mon 01 May 06 @ 2:21 pm
