I created a mix with VDJ, which is about 1h
I know I have to burn it to CD with a cue filebut in the cue file I must tipe the the currect positions (for example 12:31:15) I have one .cue file I just have to modify the numbers
In VDJ the only xx:xx:X is dislayed. I want to get the precise positions. (xx:xx:XX)
Is the a program for this?
PLZ HELP!!!
PLZ HELP!!!
geposted Tue 28 Feb 06 @ 3:53 pm
You can use Nero 6 to do just that. It works good for adding tracks to your mixes.
MS
MS
geposted Tue 28 Feb 06 @ 6:50 pm
I want to know the positions inside the mix precisely! I need the positions just like this xx:xx:XX, not like this xx:xx:X
Is there any program which can tell me the positions like this xx:xx:XX?
geposted Wed 01 Mar 06 @ 7:06 am
Hi
Try wavelab ,that is what i use to get the right setting
Cheers musicmatch
Cheers musicmatch
geposted Wed 01 Mar 06 @ 6:12 pm
thx, I will try it.
geposted Thu 02 Mar 06 @ 7:12 am
