In the default skin the beat bar at the top that shows the beat, I think its good to have it there but I think they should come up with a skin that dosent have that bar mainly for reasons like if you dont have time coded vinyls and you are mixin on stage you will have some experience other then if you were always using the beat bar to help you and your on stage wit no time code then it would be hard for you to mix as good as you want
so i think have the chance to disable the beat bar would be nice
geposted Sat 04 Mar 06 @ 4:47 am
how about dont look at it? simple solutions are often the easiest...............
geposted Sat 04 Mar 06 @ 6:38 am
