Is there a way to disable the splach screen for VDJ at startup so that it just loads the program without splash screen?
geposted Sun 05 Mar 06 @ 9:58 pm
can i ask you why???
geposted Sun 05 Mar 06 @ 10:36 pm
Because i'm running a purpose built machine for my dj'ing, keeping everything as minimalist as possible. I don't like splash screens anyway but on the odd occasion that VDJ does it's disappearing act I want to be able to double click the icon and get it back up and running again as quickly as possible.
geposted Mon 06 Mar 06 @ 9:25 pm
i dont think that the splash screen takes up any speed, its just a popup image. and besides its not like it waits for the picture before loading its loading in the background behind the picture im pretty sure.
geposted Mon 06 Mar 06 @ 11:18 pm
agree with Dj Xeo
geposted Mon 06 Mar 06 @ 11:28 pm
usually, a splash screen is used to have something visual while the rogram loads in the background.. If you could disable the splash screen, you should have the same loading time.
geposted Tue 07 Mar 06 @ 8:47 pm
