Topic: DJ cyber
This is a msg for DJ Cyber.....I would like to know how to build a gig rig like the one you have.
Thanks
geposted Tue 07 Mar 06 @ 8:34 pm
Tell him you are sorry you mispelled his name, and he will forgive you.
I've killed for less...
just kidding...
Could I get some help please?
Rig building 101
I have a SFF(small form factor) box that is similar, but can no longer recommend it, because of the 300 watt power supply. At the time I bought it, that was enough. I think the first thing you should decide is; do you want to build your system around a motherboard, or a case? Me, I picked a case and then found a motherboard that fit, and had all the things I wanted. You may want to do it the other way around. Also, do you want to use any of the stuff you have already, like hard drives, videocards, or optical drives. You want to make sure these things are compatible. That's a little to get you started. Take a look here, http://www.sfftech.com/. Remember, that you can only use Shuttle stuff with Shuttle boxes.
Thanks I want to build one around a motherboard...also I would like to know how you get the monitor to store in the box?
