Topic: Is This Possible?
Hi everyone. Read in another post a fella called "slumpriest" was asking if it is possible to record a mix as seperate tracks so to speak instead of one large long mix. or at least have it cut up so you could skip to certain tracks if i was recording a rather large mix. Hope im explainng it well enough. is this possible? never thought so but thought id give it a try. Thanks in advance for the answers/tips.
DJ Cmac
geposted Fri 10 Mar 06 @ 2:26 am
Yes you can. I don't remember where I saw this at, but there is a "cut' and "auto-cut" function. Did you try the manual?
in the recording settings you can set to cut your mix when you are crossfading
but how can I create a .cue file to chop my mix up? (because it would be more precise)
any programs?
