Topic: SAMPLE?
TotyoHome userMember since 2006
where can I get a sample which says: "DJ IN THE MIX"
(and an idea: every DJ who play in the VDJ radio should use a sample which says: "Virtual DJ in the mix")
geposted Fri 17 Mar 06 @ 4:22 pm
ahhaaa
thats a good idea.
good samples
THX
geposted Fri 17 Mar 06 @ 5:46 pm
and What do you use FL Studio?
would you make the samples with different voices?
geposted Fri 17 Mar 06 @ 5:47 pm
Bren FPRO InfinityMember since 2003
I use "TextAloud" for the voices and Cool edit pro for manipulating them, and of course VDJ to apply VST effects.
Sure I can make them using other voices, I'll try and post some more later tonight ;).
geposted Fri 17 Mar 06 @ 5:52 pm
Bagpuss,
Thx, thx, thx the previous samples
pls create a sample which says "VIRTUAL DJ IN THE MIX" vocoded, (and echo in the end)
geposted Fri 17 Mar 06 @ 6:04 pm
Done! - same link as above ;).
And your welcome.
geposted Fri 17 Mar 06 @ 7:01 pm
BIG THX Bagpuss
geposted Fri 17 Mar 06 @ 8:07 pm
owww
there is distortion in the vocode sample, so it sounds a bit bad
geposted Fri 17 Mar 06 @ 8:13 pm
hehe, I thought that was just my speakers :), i'll see if it can be fixed, it was probably the preset on the vocoder. Actually do you have msn, my adress is in my blog if you want to add me, can send you more quicker and afford to get it wrong hehe.
geposted Fri 17 Mar 06 @ 8:15 pm
pls correct the distortion and upload it to your profile, I really need this sample
geposted Sat 18 Mar 06 @ 9:02 am
fremdjPRO InfinityMember since 2004
Which software of text aloud are you using or is just a VST pluggin for VDJ, if so post the link I'm very intersting....
regards
geposted Sat 18 Mar 06 @ 5:07 pm
thx :)
geposted Sat 18 Mar 06 @ 6:23 pm
