Topic: XP10's?
Will the XP10's work with the current version 1.10 of virtual DJ?
What needs to be done to use two controllers?
How do you enable the use of the XP10?
The XP10 has a built in sound card. If two of them are plugged in at the same time, will they both work with virtualDJ?
Is there a driver for the XP10?
Can you scratch with the XP10?
Can the buttons of the XP10 be remapped?
Can you configure the wheel sensitivity of the XP10 with virtualDJ?
Does the touch plate on the top stop the virtualDJ deck? Can the sensitivity be configured?
Can you spin it back like vinyl?
Is there any videos of the XP10 being used with VirtualDJ?
geposted Sat 22 May 04 @ 12:13 am
When did 1.10 come out. I thought 1.09 was the newest. I also thought the XP-10 wasn't available yet.
OOPS, typo. I meant 1.09
1.10 is the next version and not out yet. I am very happy that atomix productions continues to listen to the DJ's and improve the product. I have showed this program to many digital DJ's and continue to recommend they try the demo so they buy it
- Just plug in two controllers :)
- Options / Remote Control / Enable
- Windows founds two usb soundcard, no problem with vdj
- It uses default USB sound card driver
- Yes u can scratch
- New version 1.09 have support for remapping buttons
- Im not sure about configuring wheel sensitivity
- You can configure touch plate.. stop or anything else.
- Sure you can spin :)
- Dont know about vdj+xp10 videos
what I would like to know will the touch plate spin with the music for that viny feel?
If you are asking do the wheels spin, I think NO. But the plate allows you to touch it, and it sends a stop signal.
hello! I want to know how and when can I buy the XP 10 ???
to go along w/ the xp10's would you guys recommend a laptop or a rackmount for both club & mobile work???
Thanks!
consider pro's and con's of each: such as weight, upgradebility, professionalism & others....
THanks!
