Topic: Help Appreciated
I have a problem. I`ve bought vdj and i`ve recorded timecode on vinyls (on my own). I`m also using maya 44 usb. I set up everything and play vinyl with timecode and try to configure soft, but vdj didn`t recognize timecode (it was equal between 0-15%). I started to looking what is wrong. First of all i tested maya and vdj by connecting mp3player (playing vdj timecode) to maya and configuring vdj. The signals ware equal (quality 100%) So i thought that its coused of diferences connected with recording a digital version of timecode on analog data. I checked that too! I riped timecode from vinyl into computer than connect internal soundcard into maya, launch riped timecode and vdj tcv configuration. Signal quality was between 90 and 100 percent (generaly 100%). So what the f... is wrong?
plz help!
geposted Thu 23 Mar 06 @ 10:35 pm
Kindly modify your profile with your serial code before you get your status questioned by users here.
There's plenty of help here, but you need to distinguish yourself from a no licence user when you state you have bought the program.
And try to use better judgement with the thread titles, ok?
Thank you
ok ;]
preamplifiers solve my problem ;]
thx 4all
