Topic: What are time-coded vinyls exactly lol?
i hav no idea lol
do you hook a vinyl deck up to ur hercules dj console? is it a special vinyl or sumthink lol ...i hav no idea
anyone? i still dont understand sum things
geposted Sun 26 Mar 06 @ 5:04 pm
erxonPRO InfinityMember since 2003
Timecode vinyl is a vinyl with a sound signature that can be processed by Virtual Dj in order to control your mp3s same way as you manipulate the vinyl record. It's hooked up to any soundcard with line-input.
Read more: http://www.virtualdj.com/products/timecode/
geposted Sun 26 Mar 06 @ 5:36 pm
l_ridsPRO InfinityMember since 2003
TCV is exactly that... a special vinyl which plays a sound that is recognised by VDJ. It comes in 2 forms, either CD which is downloadable from the website or in vinyl form which needs to be ordered. To operate the TCV of TCCD you will need a channel 4 channel input and 4 channel output soundcard. The soundcards recommended by VDJ are the Maya 44 or U46DJ.
There is more detailed information on the user guide if you wish to download it, and also if you conduct a search in the forums under TCV it will also enlighten you on my info if needed :)
geposted Sun 26 Mar 06 @ 10:40 pm
