I seem to have an issue with some of my music. Some items it will scan and some I cant get any information to display or load onto the decks. Also, can you load or store your music in vdj or do you just pull it from your media players. Thanks for any help i can get.
geposted Tue 28 Mar 06 @ 9:14 pm
answer to your second question. just open vdj on your left side it will say desktop just browse from there to your music folder. majecstik don't use crack version. buy the the program its worth it. you will get alot of support.
keEp Spinnin!!
DjHappee
keEp Spinnin!!
DjHappee
geposted Tue 28 Mar 06 @ 10:27 pm
thanks but let me get the basics first. If my music is loaded into a media player like windows, do i need to save it to my music file to be able to pull it over and scan it. thanks again for your help.
geposted Wed 29 Mar 06 @ 9:01 pm
i don't know what you meen. tell me more details
geposted Wed 29 Mar 06 @ 10:32 pm
no problem. ok i think i understand what your saying: your playing ur music on windows media player right you don't need to save ur playlist on the media player cause that doesn't matter in virtual dj. first tell me where u have ur music store.
geposted Wed 29 Mar 06 @ 11:08 pm
