IS THEIR ANYWAY TO SAVE THE VIDEOS.. IN VIRTUAL DJ?? I KNOW HOW TO CHOPP THE VIDEOS WHILE THEY ARE PLAYING BUT HOW CAN I SAVE EM.. TO A MPEG FORMAT?
geposted Thu 30 Mar 06 @ 8:15 pm
i think this is what you are asking....
you can record a dj session in mp3 format but not the video part. for that you can get a cheap dvd recorder and capture it all that way then rip it all back in via smartripper.
note the cheap dvd recorders are fine for keeping at home but often don't last long when moving them around to your gigs.
geposted Sun 02 Apr 06 @ 4:10 pm
ok so how do i set this up?
geposted Wed 05 Apr 06 @ 7:46 pm
westwood4ever,
are you referring to recording sound only or recording the video with an external dvd recorder?
Recording mp3 is very simple:
- Click on the rec button at the middle of the screen (default skin)
- Select "Record file"
- Click "Config"
- Choose a proper filelocation and filename
- Select the location of the lame encoder dll (normally in the vdj program folder)
- Click "Start recording"
Ewout
- Click "Config"
Ewout
geposted Wed 05 Apr 06 @ 10:12 pm
i'm sure here wants to record the video and sounds
geposted Wed 05 Apr 06 @ 10:27 pm
Buy a stand alone DVD recorder. Most come with hard drive's in them.
There's even such things that can record from any video source straight to MPEG-4 like the Neuros MPEG-4 Video Recorder-2. $149.99
http://svp.co.uk/products-solo.php?pid=946
The MPEG-4 Recorder is like an easy-to-use, free-standing VCR that records onto digital memory cards instead of VHS tapes so that the video is playable directly on the PSP™ , other handheld devices or ready for easy transfer to the new Video iPod™.
Instead of buying proprietary discs or downloading TV shows for a fee, you can now create open digital video files from all the content you already own. You can watch content whenever and wherever you want on your Sony PSP™, Video iPod™ or PDA.
The MPEG-4 files produced by the Recorder-2 can be played back directly on virtually any portable device accepting memory stick or CF memory cards.
You can also use the Recorder-2 to view recorded video on your TV by just plugging in to the Video-In connections on the TV and pressing ‘Play’. With your PSP™'s USB connection or an inexpensive USB adaptor/Card reader (not included), you can easily drag and drop content from the memory card onto your computer to play it on your laptop or home PC. The lightweight device fits in the palm of your hand, so you can easily take it on the road with you as your portable digital VCR.
Features:
- Record effortlessly from any video source (TV, Satellite Receiver Box, DVD players, VCR, Camcorders etc).
- Simple setup that works without a PC and operates like a VCR.
- MPEG-4 video format allows you to view content directly on your PSP™,Video iPod™ or any other device that accepts Memory Stick DUO/PRO DUO or Compact Flash (CF) memory cards (not included).
- The MPEG-4 format is also compatible with most other portable media devices.
- A great way to digitise your home movies for archiving, emailing, or playback on portables and laptops.
- Can play back from Recorder 2 through TVs and home theatres. Pocket-sized device is small enough to use as a portable VCR.
- Three resolution Settings: VGA (640 x 480) for near-DVD quality playback on TV; QVGA (320 x 240) for high-compression playback on most handhelds like the Video iPod™ and Sony PSP™; and WQVGA (368 x 208) optimized for playback of wide screen movies on the Sony PSP™.
- Four recording quality settings: Superfine, Fine, Normal, and Economy.
- Uses Advanced Audio Codec (AAC) format for high-quality stereo sound.
- Upgradeable firmware from www.neurostechnology.com for future expanded functionality.
V-Stream Xpert USB2.0 DVD Maker £22.98
http://svp.co.uk/products-solo.php?pid=492
With V-Stream Xpert DVD Maker USB 2.0, you can easily capture, author, and burn videos from any video source such as DVD Player / VCD / VHS / Camcorder, you can even Direct-Burn to DVD without any requiring extra HD space using the included CyberLink PowerProducer 2 Gold software.
Ideal for transferring an analog video signal to a digital signal so home videos can be edited on a PC. Old videotapes can be easily sent to your PC for editing and saving onto disc in VCD and DVD format.
Xpert DVD maker features a high-quality video processing & compression solution to allow video resolution up to 30fps @ 720 x 480 size, thus providing maximum quality for the user. Xpert DVD MAKER USB2.0 not only contains capturing and editing functions, but also includes software for burning, plus, your PC can be the MPEG Editor, MPEG Encoder, VCD & DVD maker.
Easily convert any video files from AVI, MPG, etc with MPEG Converter and then edit your favorite video files with MPEG Editor. Finally, you can burn a DVD / VCD / SVCD with DVD Burn.
Features:
- USB2.0 PnP Interface
- Real-Time MPEG 4/2/1 Encoding
- Burn onto DVD, VCD, SVCD
- Capture Video Source From VHS, V8, Hi8...
- Right-to-Disc
- Automatic NTSC/PAL detection
- CyberLink PowerProducer 2 Gold – allows you to direct-burn a DVD without extra HD spaces
- Edit the Video or Still Image in MPEG 4 / 2 / 1 Format
- Support Real-Time Video Recording in MPEG-4/2/1 format (MPEG4 is compatible with DivX or Microsoft MPEG4). (Note: you have to download the codec by yourself)
- Capture Video Source from VHS, V8, Hi8, etc.
- Support Still Image Capture in JPEG or BMP format
Video Resolution:
NTSC: 720 x 480 @ 30 FPS
PAL: 720 x 576 @ 25 FPS
External Video input: Composite and S-Video
Burn the Video to DVD/VCD/SVCD
The hardware comes packaged with a copy of Cyber Link's Power Producer 2 Gold software, featuring:
- Right-to-Disc Recording - DVD Direct Burn and No Need to Save in HDD
- Full DVD VR Support - Users can produce, import, and edit DVD+/–VR discs
- Playlist Authoring - Allows creation of video or slideshow playlists on DVD-VR productions
- DivX Movie Production - DivX files can be imported and burned onto CD
- Motion Menus - Lets users create dynamic menus with motion video backgrounds
- Audio Overlay - allows you insert audio in either MP3 or WAV format
- Multiple Capture Device Detection - Can simultaneously detect multiple capture devices
- Customised Photo Slideshows
Specifications:
- Video Input: Composite Video, S-Video
- Audio Input: Connect External Audio Source
- Audio Output: 3.5mm Audio Output To Sound Card Line-In
System Requirements:
- Minimum: Pentium 4 1.6GHz, 256M RAM or above
- Recommended: Pentium 4 2.0GHz for DVD record format
- One available USB2.0 port
- Graphic Card (Support Microsoft DirectX 8.1 or above)
- Sound Card (SoundBlaster 16 Compatible Sound Card)
- 1GB Free HD Space
- CD-ROM Drive (For software installation)
- Microsoft Windows XP/2000
Package Contents:
- V-Stream Xpert - DVD Maker USB2.0 Capture Box
- Installation CD
- Installation Manual
or even the
H&B TX-100 MPEG-4 USB Encoder £39.99
http://svp.co.uk/products-solo.php?pid=623
This TX-100 is the latest Video Converter for PCs from H&B, one of the market leaders for audio and MPEG-4 products.
Simply plug in the USB2 lead from the TX-100 into your PC, and the video and audio leads from your video source into the TX-100. The included WinDVD Creator software is then able to capture the video directly in MPEG2 (DVD format) or even in DivX or MPEG4 format and then send the video to the PC already in that format so there is very little work for your PC to do.
Hardware Specifications:
- External Hi-Speed USB video capture device
- MPEG-1&2 Video Converter
- MPEG-4 and DivX® (with WinDVD Creator2® Software)
- Real Time Hardware Encoding through the device, saving CPU PC usage
- VCD/SVCD MPEG-1 encoding
- DVD MPEG-2 encoding, MP@ML, Progresive and Interlaced.
- MPEG-4 endoding Codecs 3.11, 4.0, 5.0+ compatible MPEG-4 Simple Profile, @L3, B-Frame
- Audio encoding MP3, LPCM, Dobly Digital AC-3
Capture Resolutions:
Digital Video: 352 x 240, 352 x 288, 704 x 576, 704 x 480, 480 x 576, 480 x 480
Still Image: 704 x 480
Inputs:
- Composite video input (RCA connector)
- S-Video input (mini-DIN connector)
- Stereo audio input (2 x RCA connectors)
- Capture from TV, Sky DigiBox, camcorders or VCRs with composite (RCA) or S-Video output
Minimum System Requirements:
- Intel® Pentium® 4 or AMD® Athlon® 1 GHz (1.4 GHz recommended) 256 MB RAM (512 MB recommended)
- 1 Hi-Speed USB port
- Windows® XP Service Pack 2 or Windows 2000 SP4
- DirectX 9 or higher compatible sound card and graphics card (ATI Radeon or Nvidia Geforce 2 or higher recommended)
- 10MB of disk space to install software
- CD-ROM drive
I'm not really bothered about recording my Video set. But more interested in converting my DVD's ready to use with Virtual Dj. So the 3rd device seems like the best option.
I currently use #1 DVD ripper to make .avi 3ivX files for Virtual DJ. But #1 DVD ripper has a volume controll you have to set manually so for some video's it's too quiet and other's it's too loud and distorted.
Features:
Features:
- Right-to-Disc
Video Resolution:
Specifications:
- 1GB Free HD Space
Package Contents:
- Installation CD
or even the
Inputs:
- CD-ROM drive
geposted Wed 05 Apr 06 @ 11:27 pm
