its only available with dj console buttons the new skin has a seperated mixer with all important functions. No, the arm on my skin works regular. The default skin is buggi and yours too.the tonarms on your skin are not synchron when the music is playing and your skin is to full with dobble functions and not detailt. my armes move synchron with the music and i have all features of 3.3 and the 3.4 functions is coming up.Ätsch. you can try self activate the buttons on skin if you need.
geposted Fri 05 May 06 @ 3:36 pm
What's all that criticism? I'm using Cioce's regularly and I can say it's the best with DJC or not. It has buttons in the right places, and you can access every command easily. Why say it's useless than your? This is the worst way to advise your skin... I never say others' things are gardbage, but I always try to say what's wrong... I say they suck only if they really suck!
geposted Fri 05 May 06 @ 4:09 pm
Nico, if that is how you wanted the skin to work then OK. We are not saying your skin is bad, just different.
Other VDJ users that don't have HDJC will not be able to use your skin, we did not know it was only for console users and the arm movement is 'different' from what we are used to.
Good job anyway the skin still looks good but I like your previous version better.
geposted Sat 06 May 06 @ 12:22 am
The buttons will be activate with better solution of Features on skin.
geposted Sat 06 May 06 @ 9:58 am
© FRUTY SKIN VIRTUAL DJ (DJC MK2 UPDATE) VERSION 3.4.9 OUT NOW !
LINK: http://www.virtualdj.com/addons/download.html?addon_id=1707
geposted Fri 09 Jun 06 @ 7:48 pm
nico anders please read carrefully BB Code disclaimer. Next time you'll be banned from using BB Code.
geposted Fri 09 Jun 06 @ 7:58 pm
geposted Sat 21 Oct 06 @ 2:47 pm
can't find this skin
can someone tell me under what name is it?
geposted Sat 28 Oct 06 @ 11:48 pm
out of time.sorry
ask anybody maybe send the skin to you
http://www.kram-hochladen.de/returnfile.php?id=OTkwOA==.de
(Skin update without script)
geposted Sun 29 Oct 06 @ 1:46 am
thanks for the reply, but i didnt get anything from that link, it appears to be dead or sumthing.
ok, so, if anybody has this skin and took some time to send it to me at this email erduan_ed@yahoo.com i'd be very grateful. i'd like to see this skin and give it a try.
thanks
thanks
geposted Sun 29 Oct 06 @ 11:25 am
copy the linkwith rightclick and put into new explorer and press enter
geposted Sun 29 Oct 06 @ 5:14 pm
Hi!
URL does not go! :(
Would Y' have 'it average to arrange that? please
URL does not go! :(
geposted Fri 24 Nov 06 @ 10:42 pm
