Topic: hdx or xp10
what is the better choice for vdj hdx or xp10
geposted Wed 05 Apr 06 @ 2:33 am
No1 has the hdx yet but on the face of it... it looks pretty good. You can buy my xp10's if you like :)
::cough:: ehe, if you're serious, i'll buy em! lol
but does anybody know if it is compatible with vdj the way the xp10 is, and how much does the hdx cost
$ 1800 retail O_O
but it's fantastic.... thinking 2 take one
Timecode mode works differently than a controller.
If you want my opinion don't pay that much for an advanced cd player unless you really need something like cdx, means you still use audio cd's.
Timecode control is basic and always require the timecode to play for any changes in the software, so you can't do nothing "offline", also all advanced dsp functions will be ignored.
the HDX and XP 10 are totaly different things, With the HDX tho you can use the buttons as midi controllers so it gives you a liiittllleee more functionality. XP 10 is a tiny fraction of the cost. wait for news on the XJ 10
Next generation of XP10 would be almost the same as hdx ;)
when used with VDJ it will be the best solution there is. There is nothing missing
DJ Xeo, you forgot to mention which of the two options you are referring to.
What is best for you depends on your needs.
The hdx looks nice, you could play cds and songs from the internal harddrive, but they are quite large, heavy and expensive. On the other hand is playing from the hardrive useless (in my opinion) in combination with VDJ.
The xp10s are small, cheaper and a real contrroller instead of timecode, but looks less impressive, buttons are less in quality (only what I heard).
If you have some time, you could wait a little to more information is available from Numark or the next version of the xp10.
Ewout
VDJ 4.0 and XJ10s, video, moving platter, effects, a RAID array of music. beat that.
Using HDXs just for VDJ would be overkill. If anything HDXs are hardware equivilents of VDJ not realy tools for it.
they are going to weigh a ton
EDIT: The HDXs that is:P
true.... Get XP10 or regular turntables with timecode vinyl, if you are gonna use it with VDJ.
HDX would be over-kill :)
so i think i should go with the xp but dj xeo you just put xj10 is thet a new type or what and who knows when is vdj 4.0 coming out
