Topic: Gigaport External Soundcard Question
milesdjPRO InfinityMember since 2005
I recently purchased VDJ and using the Gigaport 150 as my external soundcard. Not sure if I have the setting set correctly in VDJ but I'm only getting one channel to play input 1&2 Left.Right. Can you tell me which setting I need in the Soundcard setup?
geposted Wed 05 Apr 06 @ 9:20 pm
milesdj,
welcome on board!
The settings are dependent of your own needs. Do you like to use vdj with an external mixer? Would you like to use 1 stereo channel having master out and 1 stereo channel for headphone?
If you like to use VDJ with an external mixer you could use the "4.1 configuration with mixer" (6th option). Aftyer selecting this option you will have to select the proper sound card.
You also could use the "Advanced config". After selecting this option you should click on the "Config" button and select each channel by hand.
If you require different settings please let us know.
Ewout
geposted Wed 05 Apr 06 @ 10:38 pm
