Is it possible to change the fade entry/exit points? I have some videos that are more like movies in the begining and at the ends. When people are dancing, kinda sucks when the music stops and they start watcking tv. Be nice to start it at another point. Maybe editing the clip is the way. Not sure how that would work either.
geposted Thu 06 Apr 06 @ 8:52 pm
1. you can edit the videos in a video editor
or
2. you can mix manually
or
3. you can change the fade in/out for the automix
- this you do when a video is loaded to a deck, and you right click the same file in the brownser.
Choose edit bpm, and you can also edit fade settings in the window that pops up
Hope that helps :)
geposted Thu 06 Apr 06 @ 9:04 pm
