Topic: Earphone And Mixing
Ok, Is it possible to use virtual DJ With Earphones While mixing two songs. By this I mean can I play one song on deck A through the speakers and another song on deck B through the earphones and when I want to mix the two songs together use the crossfader to bring the song from deck B that im listening to on my earphones into play through the speakers while listening to the mix in the headphone as well as through the speakers. Thanks
geposted Fri 07 Apr 06 @ 10:47 am
yes it is possable in the full version of VDJ i'm not sure if it is in the trial version, but it is definitly in the full version.
geposted Fri 07 Apr 06 @ 11:27 am
Bren FPRO InfinityMember since 2003
The Trial Version is locked to one output, this is A limitation which also helps to prevent piracy.
geposted Fri 07 Apr 06 @ 11:47 am
