Sorry but we are left out in the cold on this one . The BCD200 is a good idea gone bad by crappy software and incomplete midi implementation. Nothing was very well thought out when all of this started. So it's going to be a bumpy road from here.
geposted Sat 20 May 06 @ 4:02 pm
The definite solution for BCD2000 Behringer and VirtualDJ stay here:
www.macfruits.com/bcd2000
Don't spend more time (and money)
Come here and discover it.
All updated and free. Antonello migliorelli
geposted Sun 21 May 06 @ 2:22 pm
Thank-you very much!
Finally someone had the balls to post the solution!
geposted Sun 21 May 06 @ 9:39 pm
yes, it works!! but i have a little problem with the headphone mix, when i play deck A i cant hear deck B in the headphone. how can i set this fonction????
thanks a lot!
thanks a lot!
geposted Mon 22 May 06 @ 12:13 am
have you managed to get the Mic "on Air" ?
geposted Mon 22 May 06 @ 1:20 am
Hi to all.
On-air button is set as record func.
Headphone must be set in your audio configuration:
Select Advanced Config and set:
Left Deck
BCD2000 ASIO - Channel 1
BCD2000 ASIO - Channel 2
Righ Deck
Headphone
BCD2000 ASIO - Channel 3
BCD2000 ASIO - Channel 4
Prelisten
Then you will listen it.
If all prefer Headphone as a crossfader (and not mixer) i can set it.
I also want to know if you like the scratch system.
BYE. Antonello (PS potete scrivere anche in italiano io lo parlo tranquillamente)
Left Deck
Righ Deck
Headphone
Prelisten
geposted Mon 22 May 06 @ 1:33 am
I can't see nothing at the web site please help me
geposted Mon 22 May 06 @ 3:08 am
I would like to get the scratch system too
but if somebody could tell me how to invertir the pitch will be great!!!!!
geposted Mon 22 May 06 @ 3:25 am
eh? wheres the zip file?
geposted Mon 22 May 06 @ 11:50 am
How do we get the older version of the midi translator?
geposted Mon 22 May 06 @ 1:01 pm
just tried the translator etc with my mates laptop and his registered version of Virtual DJ, it just makes it run slow etc
come on Virtual DJ people help us out here
geposted Mon 22 May 06 @ 1:23 pm
first of all: Thank's a Lot Mccoy for your work.
I see that you mapped the "on air" button to the record function, is there a way to use it as it is supposed to? ->switching mic on and off? Or is there any other way to use the mic?
geposted Mon 22 May 06 @ 2:00 pm
I can't help you to find it (midi translator v1.31).
The pitch is difficoult to invert (hardware problem)
The link for download now func.
BYE.
BYE.
geposted Mon 22 May 06 @ 3:59 pm
I can set you "ON AIR" button as original func if you want but i don't know if it will func with the hardware (shortcut modify only software-VDJ function).
geposted Mon 22 May 06 @ 4:02 pm
For those of you who can't find the V1.31 of midi translator. Try V1.4 and import mccoys ini-file with the import function. This worked for me.
@mccoy:
V-DJ has a midi function for mic:on/off? I only found something for mic-volume but no assignment for switching mic on/off.
Greetings from rainy Germany ;)
@mccoy:
geposted Mon 22 May 06 @ 11:31 pm
If you want to set a volume for mic ON/OFF you can try to set volume 0 on "off state" and volume 1 (or something else) on "on state"
geposted Mon 22 May 06 @ 11:48 pm
mccoy, thanks for some nice piece of work.
I find however that when I press the (scractch) button on the bcd, the 'beatmatch' button on VDJ lights up. also, when I press the (sync slave) button on the bcd, the 'loop' button on VDJ lights up.
Anyway to fix this?
thank-you
BC
Anyway to fix this?
thank-you
BC
geposted Tue 23 May 06 @ 2:07 am
Well ive seen the solution you guys recommend, however i dont get it??
Are we supposed to run 2 programs alongside VDJ for the BCD2000 to work?
Midi Yoke and Bomes miditranslator?
There must simply be a simpler way.. how can we contact the VDJ officials and get some word on wether or not the next VDJ will support the BCD2000? If not, well it might be time to begin looking
for something else.
//cosmo
www.mmradio.org
for something else.
//cosmo
www.mmradio.org
geposted Tue 23 May 06 @ 2:24 am
I asked and the answer was very vague
geposted Tue 23 May 06 @ 8:02 am
I totally agree with your way of thinking VDJ should at least have the courtesy to tell us whenever they are going to support the BCD yes or no so we as being their client could decide on what to do .
geposted Tue 23 May 06 @ 8:44 am
