Topic: How to connect a mixer with pc?
How do i connect a mixer to pc?
do i need maya 44 usb or something else???
http://img127.imageshack.us/img127/8016/mixer1kp.png
on this picture i see that you can connect you're mixer to a 4.1 soundcard
How do i do this?
wich connections must i make?
I have the home edition but if i have my new mixer i will buy VDJ PRO
DJ IbiziX
geposted Wed 12 Apr 06 @ 1:45 pm
xeonPRO InfinityModeratorMember since 2004
You can do like as you saw at picture. If you buy pro version and if you have 4.1 soundcard it is possible. You can also use maya44 as very good soundcard.
geposted Wed 12 Apr 06 @ 3:05 pm
but in wich contacts is must put everything?
and wich cables do i need?
geposted Wed 12 Apr 06 @ 8:56 pm
geposted Wed 12 Apr 06 @ 9:07 pm
in wich contacts of the mixer must i put the cables?
and in wich contacts of my 4.1 soundcard?
geposted Wed 12 Apr 06 @ 9:27 pm
You need 2 cables. They should be 1/8 inch stereo on one end, and 2 RCA on the other end. The 1/8 inch goes to the sound card, and the RCA, goes to the mixer channel 1. Then repeat for the other side of the mixer, channel 2.
geposted Wed 12 Apr 06 @ 9:45 pm
geposted Wed 12 Apr 06 @ 10:23 pm
what is the 1/8 inch stereo?
i don't find anything :s
geposted Wed 12 Apr 06 @ 10:24 pm
geposted Wed 12 Apr 06 @ 10:26 pm
"the smaller one connects to your PC line in."
Shouldn't that be "PC line out"? I am also sorry about that 1/8 inch thing. I thought it was 1/8 inch. Does anyone know if that converts to 3.5 mm? BTW, that's the way I have my setup. I just use a different sound card, to my external mixer.
geposted Wed 12 Apr 06 @ 10:48 pm
It depends what he wants to do, that's why I asked. I'm assuming he wants to connect his mixer to his PC to record although what you said is perfectly valid if he wishes to do the opposite and send audio from his PC to his mixer. Although I'm not sure this functionality exists in Home Edition.
geposted Wed 12 Apr 06 @ 10:58 pm
I see your point. I quess we should know which way he want's to go.
geposted Wed 12 Apr 06 @ 11:02 pm
i want to use a mixer to control virtual dj -> if i use the crossfader on my mixer it will be the same way in virtual dj
(just lik the hercules console)
i will buy pro version soon!
geposted Thu 13 Apr 06 @ 9:22 pm
For this you have to use mixer that has midi outs. Like numark has a few of them with usb.
geposted Thu 13 Apr 06 @ 11:00 pm
geposted Fri 14 Apr 06 @ 7:08 pm
