Topic: humming with timecoded vinyl
hey,
I just want to say first off that I really like virtual dj with the timecoded vinyl feature. I am wondering about a wierd noise that I heard when I turned the speakers up. The noise sounded like the timecoded vinyl does when you are not playing a song, but this noise was louder than the sound. Do I have to ground the tts to my laptop, or is this a bug with the vinyl?
thanks for your help in advance!!
geposted Sun 16 Apr 06 @ 3:09 am
if you are hearing the timecode noise through the final output make sure that 'monitor inputs' or whatever its called on your sound card is dissabled and that your mixer doesnt have bleed from the phono stage to the line stage when using the switch to change between line and phonon, when both are plugged in.
