Hello,
VirtualDJ will not play certain songs. And once it rejects a song from a particular album, it will not play any song from that album. It just says "ERROR", and with no explanation as to what the error is.
Has anyone encountered this problem before, and can you offer any suggestions?
Thanks.
Thanks.
geposted Thu 27 Apr 06 @ 1:40 pm
Did you moved or renamed this particular album since the first time VDJ analyzed it ? It could be this... This to rescan your HD in this case.
geposted Thu 27 Apr 06 @ 3:05 pm
Slash4, thanks for your response, I do really appreciate it!
Sometimes the "ERROR" will occur when I've try to play sons from my own compilation, but it has also occurred when I've tried to play songs form original albums; such as Religious Albums.
Any additional thoughts you or others have would be great.
Thanks again...
Thanks again...
geposted Thu 27 Apr 06 @ 8:01 pm
So the question is : did you managed to play them at least 1 time in VDJ or since the begining it's bad ?
geposted Thu 27 Apr 06 @ 9:32 pm
Slash4, the answer is no. I usually get the ERROR the very first time, and thereafter.
geposted Sun 30 Apr 06 @ 2:32 pm
