hi i suppose all of you are tired of new ppl asking this question, but..
how do i use the pre-listening function. plz could u give me step by step instructions.. plz? im only new!
geposted Fri 28 Apr 06 @ 9:49 pm
The prelistening function using a 5.1 soundcard for example is only available in the full version.
Ewout
Ewout
geposted Fri 28 Apr 06 @ 9:57 pm
um... and presuming that i buy the full version. how do i set it up then?
geposted Fri 28 Apr 06 @ 10:13 pm
You will need a 5.1 sound card, two sound cards or a professional soundcard with multiple outputs. You could set it up in different ways:
- Connect 1 of the outputs to your amplifier (master sound) and attach your headphone to the other output (pre listen)
- Connect both outputs to an external mixer and pre listen using the mixer
Ewout
ps, try using the search button on the forum, thiese questions have been answered multiple times already
ps2, reading the VDJ manual will help also
Ewout
geposted Fri 28 Apr 06 @ 11:55 pm
Superstorm whats does Ewout means i notice u say that all the times lol
geposted Sat 29 Apr 06 @ 8:27 am
His name? Didn't thought of that, did ya :)
geposted Sat 29 Apr 06 @ 11:41 am
lol probbaly its his name =D
geposted Sat 29 Apr 06 @ 11:46 am
2 are going for gold (Erxon, djarmen): my first name is Ewout. Superstom is just a nickname.
Ewout
ps, my name is not used often, therfore I set it under most of my post. If I search the forum, I could simply locate my posts.
Ewout
geposted Sat 29 Apr 06 @ 9:10 pm
