I want to connect 2 Denon DN-S5000 to a Hercules mk2 controller. Will this cover everything I need to scratch video via midi through the MK2 and TCCD through the Denons? Basically what I want to know is, besides my computer, do I need anything else to have full control of video crossfades, scratching, etc....
Thanks in advance!!!
geposted Wed 03 May 06 @ 10:08 am
you are covered;) that will work
geposted Wed 03 May 06 @ 10:15 am
Thank you for the quick response. I will order the Herc now!!!
geposted Wed 03 May 06 @ 10:26 am
Some addition.
There is no need in controlling VDJ with midi using the Heercules DJ console. This DJ console has native support within VDJ. So you just have to install the drivers of the console, attach it and start VDJ.
Ewout
Ewout
geposted Wed 03 May 06 @ 7:37 pm
Or not install the drivers. Not sure about the new MK2, but if I recall correctly, the original HDJC did not *require* that the drivers be installed. The native support in VDJ allowed the HDJC to work fine without any drivers being installed. Same goes for xp10.
geposted Wed 03 May 06 @ 10:25 pm
the controller will work fine without drivers...
But the soundcard would need drivers... :)
Its own, or asio4all or other general drivers
geposted Wed 03 May 06 @ 10:44 pm
