Hi all,
This is off topic from VDJ, but is a DJ question nevertheless. I am looking to purchase a mixer, I have two numark turntable (1600tt & 200) and looking for a solid scratch mixer for them, two channel. Right now I have a numark 2050 mixer, which is terrible because it's three channel (any DJ knows that extra inch & half really slows up your cuts, breaks...etc).
Anyway, my question is can you all recommend any solid mixers? Maybe that you have used yourself and are pleased with it.
Thanks!
Thanks!
geposted Thu 04 May 06 @ 8:05 am
Try here:
http://www.virtualdj.com/forums/48290/Hardware_Technical_Support/What_type_of_mixer_.html
http://www.virtualdj.com/forums/46903/Hardware_Technical_Support/What_Product_Is_The_Best_For_Video_Mixing.html
http://www.virtualdj.com/forums/46818/Hardware_Technical_Support/Should_I_buy_This_Mixer_.html
Hope this helps
Hope this helps
geposted Thu 04 May 06 @ 9:45 am
Thank you much sir, helped tons!
geposted Fri 05 May 06 @ 2:18 am
Sometimes it's easier to search inside a FORUM.
Lot of things have been talked before.
geposted Fri 05 May 06 @ 10:20 am
