I have been using VDJ for about two weeks with no problems and it sounds great. My timecode quality says 0% and plays fine, do I need to get it to say 100%..???
what mode should I be using? Also what is the difference between the modes?
1. absolute
2. smart
3. relative
**MODERATOR** - Your second Thread has been deleted and joined to this one as the subject was the same.
1. absolute
2. smart
3. relative
geposted Thu 04 May 06 @ 4:56 pm
Make sure your sound in is muted on your sound card (one), and yes, it would be good that it shows 100% cuz if not then u will have problems of it not responding correctly (two).
BTW, what sound card are u using?
geposted Thu 04 May 06 @ 10:17 pm
maya 44 soundcard
geposted Thu 04 May 06 @ 11:52 pm
LOWER the volume at the inputs.. 100 % is only needed for scratch
geposted Fri 05 May 06 @ 12:23 am
Probably the input of the TCCD is too loud. Lower the volume in the maya config. To open this config: VDJ->Config->Sound card setup->lowlatency timecode vinyls->Config timecode->Asio config
Ewout
Ewout
geposted Fri 05 May 06 @ 12:27 am
