How about this option that was available in pcdj? When I drag a song from the playlist onto a player, it is removed from the playlist. It would be useful if it didn't do this - I'd rather keep the playlist intact, as I'll often change my mind and decide to load a different track, but I'll have to do a search for that playlisted track again, 'cos to load it is to delete it.
geposted Fri 05 May 06 @ 5:49 pm
That is why the side list was added. If you have songs in the side list, they will not be removed if you drag a song to a player.
Ewout
Ewout
geposted Fri 05 May 06 @ 8:56 pm
Hi,
Not exactly the same as PCDJ, but you can use "Repeat Playlist".
I found this to be good when you're in that atmosphere where you change your mind a lot.
-Hope that helps, Dj Los.
geposted Sat 06 May 06 @ 4:42 am
Ahhh... hadn't even tried that button - i assumed it was something to do with autoplay! That's great, I can continue to be my usual indecisive self when working - thanks!
geposted Sun 07 May 06 @ 4:18 am
