Hola no entendi la explicacion que Vnz hizo para explicar lo del reloop con el sampler.
Esto fue lo que explico en el foro general.
You have to create 2 keyboard short cuts to achieve what you want. Go to: config, keyboard sortcuts, add, samples, sample, enter # of sample you want to re-play and press the key you want to use to re-play the sample. When you are done you need to do this exactly the same one more time. Now that shorcut will re-play your sample without stopping after you trigger it.
P.S: You will not be able to trigger your sample with this key. You will have to create another shortcut for that. For instance and use the "f" keys to trigger my samples and my "num lock pad" keys to re-played them.
Hope this help
With the 2 same shortcuts of the SAME key, VDJ will stop your sample and will re-play it from the beggining without any pause or gaps. Make sure both shortcuts are using the same key # for 1 sample.
If you want your sample to stop at any point after that just use your other shortcut that triggers and stops your sample. Use different key # for that.
Now, If you dont want your samples to loop, just uncheck "loop" under the sample settings or record your samples as Jingles.
Also, I use another shortcut that will play my samples temporary as you press the key, when you let go it will stop and if pressed again it will start again with no gaps. This is almost like a transformer effect.
For this effect just check the box that says "temporary" in the shortcut setting.
NO ME MANEJO MUCHO CON EL INGLES, ASI K NO PUDE ENTENDERLO A CABALIDAD.
SI ALGUIEN FUERA TAN AMABLE DE EXPLICARMELO SE LO AGRADECERIA MUCHO.
Hope this help
geposted Mon 08 May 06 @ 6:12 am
Lo unico que tienes que hacer es crear un shortcut dos veces para el mismo sample, por ejemplo digamos sample F1, al presionar F1 se ejecuta el sample, luego asigna un shortcut con SHIFT + F1 y dale otra asignacion con el mismo SHIFT + F1,(es decir haslo 2 veces) ahora te vas al sample que esta tocando (F1) presionas SHIFT + F1 las veces que quieras y se produce el reloop, lo mismo pasos debes hacer con todos demas los samples
espero haberme explicado.
NOTA: el reloop funciona solo cuando esta un sample activo es decir luego de presionar F1 por ejemplo no se reproduce directamente al presionar SHIFT + F1, creo que eso es lo que estan pidiendo para la nueva version de VDJ, mejor control de los samples
saludos y gracias nuevamente a VNZ dj por la explicacion
geposted Mon 08 May 06 @ 6:25 am
PERFEXXXTO MAN, AHORA SI K SI :P
GRACIAS POR LA AYUDA.
SALUDOS
SALUDOS
geposted Mon 08 May 06 @ 7:34 am
Esto también se puede hacer con el botón derecho del ratón pinchando en "Play".
También existe una función en la configuración llamada "momentario" la cual puede hacer la misma función. (VDJ 3.4)
http://www.virtualdj.com/blog/damarvi/blog2837.html
Atentamente
DaviD BiT
Valencia- Spain
Atentamente
DaviD BiT
Valencia- Spain
geposted Mon 08 May 06 @ 10:07 am
a ver ya que hablan de samples......
como se le podria dar la opcion SONG_POS a los samples ...lo que yo quisiera es samplearlos osea que al apretar el boton se regrese al comienzo pero de un modo fino....como si tuviera un punto cue mas o menos asii
geposted Mon 08 May 06 @ 7:12 pm
con estos shortcuts se puede hacer lo de los samples para q se repita el sample cada vez q se aprieta el boton
Key="F1" action="sample" value="1"
Key="F2" action="sample" value="2"
Key="F3" action="sample" value="3"
por:
Key="F1" action="sample" value="0"
Key="F2" action="sample" value="0"
Key="F3" action="sample" value="0"
lo uniko que no se porque solo se puede usar un sample a la vez osea si activas uno se desactiva el otro
como se arregla eso
pd: info sacada del foro en ingles (general)
por:
como se arregla eso
geposted Wed 10 May 06 @ 11:04 pm
Gracias Arturoski...
Cuando tendremos el gusto de tenerte como usuario Pro?... estoy seguro que ya tendrías un nivel superior si hubieses adquirido tu software desde que entraste ala comunidad...
Saludos!!!
Saludos!!!
geposted Thu 11 May 06 @ 12:09 am
Se te desactiva el sample porque estas poniendo una misma combinacion de teclas para otro sample, aca te dejo un cuadrito, para que te orientes. Trata de ser ordenado.
Reloop
Sample Valor Tecla Tecla Tecla
1 1 F1 Shift+F1 Shift+F1
2 2 F2 Shift+F2 Shift+F2
3 3 F3 Shift+F3 Shift+F3
4 4 F4 Shift+F4 Shift+F4
5 5 F5 Shift+F5 Shift+F5
6 6 F6 Shift+F6 Shift+F6
7 7 F7 Shift+F7 Shift+F7
8 8 F8 Shift+F8 Shift+F8
9 9 F9 Shift+F9 Shift+F9
10 10 F10 Shift+F10 Shift+F10
11 11 F11 Shift+F11 Shift+F11
12 12 F12 Shift+F12 Shift+F12
¿Para que es la repeticion de teclas como en el caso de "Shift+"x" y porque se mantiene activo el sample?
Porque solo nuestra tecla principal (la que no se repite) nos sirve para activar o desactivar el sample, lo que realiza el atajo de teclado repetido es crear un OFF-ON a la velocidad del rayo por asi decirlo, no logrando nunca desactivarlo, es decir, F1 activa-Shift+F1 desactiva-Shift+F2 activa y asi se mantiene el ciclo siempre activo, pero haciendo que el sample vuelva al principio.
La tecla repetida no te servira para activar el sample ya que compliria una funcion de ON-OFF, es decir lo activa uy desactiva tan rapido que ni lo escucharas.
Saludos.
Reloop
Saludos.
geposted Thu 11 May 06 @ 9:25 pm
Maldicion se desordeno la tabla, aca te dejo un link para que la vea en excel.
http://www.djtakeda.unlugar.com/tabla.JPG
Saludos a todos.
Saludos a todos.
geposted Thu 11 May 06 @ 9:30 pm
gracias pana solo otra cosa mas
tengo q hacer 2 veces la combinacion shift + x
geposted Sat 13 May 06 @ 12:40 am
Si amigazo, de lo contrario la combinacion Shift+x solo detendra el sample.
Saludos.
Saludos.
geposted Sun 14 May 06 @ 4:26 am
Estan correcto. (Dos veces el mismo shortcut para un sample). Me alegro que lo hallan podido hacer trabajar.
Saludos..
Saludos..
geposted Sun 14 May 06 @ 4:55 am
