Topic: Setup in 2.0 of a Gigaport Soundcard With External Mixer
Just wanted to ask this question now if anyone figured this out yet. I was having difficulty setting it.
I have the Gigaport sound card. I was able to get the right and left channels set up and cd 1 and 2 in the advanced config. area of the setup screen (fade left and right on the board), however, how can you make the loops work? There is no way to get the loops to play out of both channels or to come out of two different channels of the soundcard. The only way I can think is to select a different soundcard, maybe the internal and run a seperate channel to the amp. Am I right or was I setting it up incorrectly. Thanks for the help...
geposted Fri 11 Jun 04 @ 6:21 pm
cedricPRO InfinityMember since 2003
same problem. seems that everybody has got the same problem.
cedric
geposted Fri 11 Jun 04 @ 6:43 pm
