Hi All. If I mass rename files that I have already analysed and set cue points for in VDJ, will loose I all this info.
Thanks
sla200x
Thanks
sla200x
geposted Sat 13 May 06 @ 12:17 pm
I think you will not because VDJ has some crc check so it knows it is the same files. Just don't change files (like volumes, normalizing) and don't change ID tags.
geposted Sat 13 May 06 @ 8:16 pm
Basically the file will remain anaylsed (in VDJ) as long as it's size is not (by any means) altered.
geposted Sun 14 May 06 @ 12:10 am
Well said, Bren :) !
geposted Sun 14 May 06 @ 2:58 am
Thanks guys. This was helpful.
Sla200x
Sla200x
geposted Mon 15 May 06 @ 12:09 am
