Hi... i was searchin around the other week and found atomix Free Trial mp3 verison... as it was free i decided to give it a go... my frendz asked me if i could make them a tune so i decided why not... so after i made my mix usin the record button i decided it was really good and decided to send to all my freinds... but when i came to send the file was like 20,000 kb... i have seen mixes roughly about 7 minutes long no way near as big as that file e.g Dj-Rankin Megamix
so is there anyway of sizing my tune down to send to my freinds?
please plase tell e every possible way
geposted Sat 13 May 06 @ 1:33 pm
anybody?
please
please
geposted Sat 13 May 06 @ 1:51 pm
You need to Google WAV to MP3 converters. There are plenty of free sound converters out there as AutoMixMP3 records in .WAV files, which have great sound quality but are too large. But VDJ records in MP3 as well as WAV. MP3s are compressed sound files that take up less space. So go with MP3s and try VDJ trial. http://www.virtualdj.com/download.html
Try both and see which one works best for your computer set up.
MS
MS
geposted Sat 13 May 06 @ 1:57 pm
okay lmao i didn;t get a word of that... so can't i convert it in atomix i need a different program?
geposted Sat 13 May 06 @ 2:02 pm
Try this program
http://www.mp3-converter.com/mp3_converter_freeware.htm
Or this one
http://www.e-soft.co.uk/
Both are free programs
Remember that a free trial is just that a trial. AutoMix is a good program but there are many feature that are disabled because it is a trial offer.
MS
Or this one
MS
geposted Sat 13 May 06 @ 2:07 pm
so if i record on these programs the size of the track will be normal like 2000kb or so
geposted Sat 13 May 06 @ 2:14 pm
What you do is take the mix that you have already recorded with AutoMix, drag it into one of this programs and convert it into a smaller program. What this programs do is convert big files into smaller ones.
MS
MS
geposted Sat 13 May 06 @ 2:21 pm
gone on http://www.e-soft.co.uk/
and took the audio converter/audio grabber
will it do?
if so thanks for the help
will it do?
geposted Sat 13 May 06 @ 2:31 pm
Try and let me know...
MS
MS
geposted Sat 13 May 06 @ 8:58 pm
