Topic: NEW CONTROLLER
geposted Sun 14 May 06 @ 12:36 am
DJ-ALFPRO InfinityModeratorMember since 2005
A little small but good for mobile DJ's, nice for carrying around. The price is around £149.00 GBP.
geposted Sun 14 May 06 @ 2:57 am
I am considering purchasing this, it is almost exactly what I am looking for. I am still goingto try and build my own midi based mixer first.
geposted Tue 16 May 06 @ 3:12 am
l_ridsPRO InfinityMember since 2003
Really tiny and cramped huh. Not bad for those with space issues.
geposted Tue 16 May 06 @ 3:27 am
Since it uses both note-on and Control change events with equal values it won't fully work with VDJ as-is since VDJ won't know the difference between note-on #13 and CC #13 (as an example..)
geposted Tue 16 May 06 @ 5:52 pm
abnormPRO InfinityMember since 2003
paulheu, I was about to buy this controller. Can you explain further why this controller is not fully compatible with VDJ? I am new to midi.
geposted Mon 22 May 06 @ 12:33 am
No one else has actual experience with these? I've been thinking of getting one for a long time.
geposted Mon 22 May 06 @ 10:43 pm
the hercules mk2 is much better
geposted Tue 23 May 06 @ 12:26 am
Thanks for the reply leelars74, but I use VDJ with external mixers at clubs and need a small controller to use instead of the laptop keyboard. That is why I am interested in the Faderfox DJ1/DJ2. If anyone knows that this unit is compatible with VDJ, please let me know.
geposted Tue 23 May 06 @ 3:59 am
HI
I like the look of this controller, but .. .. .. even if it was compatable with VDJ.
Some of the controls might be superfluous if you're using an external mixer???
Wouldn't need a crossfader and would want to monitor through proper mixer.
So the important actions for a controller are to select track, set pitch, start stop cue and loop and maybe some fx work.
I'n not so sure how this unit would feel doing that, because there might be a tendency to hit the crossfader when busy.
Is this any better than using a cheap twin CD deck with Time Coded CD except that it is much more compact.
People who use it with Traktor seem happy enough with it though.
Asymptote
geposted Tue 23 May 06 @ 3:13 pm
Asymptote,
you could use the crossfader of your mixer for sound and the one on this controller for video.
Ewout
geposted Tue 23 May 06 @ 6:41 pm
Yeah, I guess so.
I don't use video at the moment, but should think about it really.
Asymptote
geposted Tue 23 May 06 @ 11:39 pm
I like the lamur controller, but it is a little expensive.
Ewout
geposted Thu 25 May 06 @ 6:03 pm
