is there a way to change the font for the text when you are playing videos? Is this a old topic or should I throw it in the new ideas forum.
BTW, Virtual DJ Rocks ! I started with version 1.0 and it will always be ahead of the rest.
geposted Wed 17 May 06 @ 11:42 am
textzone textfont1 2 3 4 etc and you can click your wish textfont
geposted Wed 17 May 06 @ 11:57 am
???? where do I use that? is there a config file for it or is a skin thing?
geposted Wed 17 May 06 @ 10:10 pm
in xml script http://www.virtualdj.com/support/developers/skin.html
geposted Thu 18 May 06 @ 9:36 am
If you want to change the font of the video text written by hands during video mix is not write in the skin xml and not possible to change.
You can only change the size and the color.
geposted Thu 18 May 06 @ 3:55 pm
